E70 wheels fit F15
Posted: Fri Sep 14, 2018 5:13 pm
by mark hamster 28
As above. I read you can do something to get E53 fit E70 and wondered if possible to do E70 onto F15, thanks.
Re: E70 wheels fit F15
Posted: Fri Sep 14, 2018 5:58 pm
You need to find the centre bore diameter on both axles for both cars and PCD (where the bolts are relative to the centre) measurement.
If the F15 has a larger bore then you will need machining done, if the E70 has the larger bore you need spigot rings. If both the same then perfect. I expect the PCD will be the same across all models given they are all 5-bolt fitting.
Posted: Sun Sep 16, 2018 11:14 am
by mark hamster 28
thanks for that X5 sport. Is there any where that sell these ? Found a nice set off winters but fit E70
Posted: Sun Sep 16, 2018 12:53 pm
You’ll need to know what the differences are and then look on eBay etc for spigot rings,
