E70 wheels fit F15
mark hamster 28
E70 wheels fit F15
Post by mark hamster 28 » Fri Sep 14, 2018 5:13 pm
As above. I read you can do something to get E53 fit E70 and wondered if possible to do E70 onto F15, thanks.
::) X5 M Sport F15  3.0D M Sport  ::)
PREV-
New Model X1 Xline 2.0 D 2015
X 5 M Sport 3.0 D (E70) Only been gone 2 days but missed  :(
Ford Focus ST3
Audi A4 Cab Final Edition
Range Rover Sport HSE
Re: E70 wheels fit F15
Post by X5Sport » Fri Sep 14, 2018 5:58 pm
You need to find the centre bore diameter on both axles for both cars and PCD (where the bolts are relative to the centre) measurement.
If the F15 has a larger bore then you will need machining done, if the E70 has the larger bore you need spigot rings.  If both the same then perfect.  I expect the PCD will be the same across all models given they are all 5-bolt fitting.  :)
mark hamster 28
Post by mark hamster 28 » Sun Sep 16, 2018 11:14 am
thanks for that X5 sport. Is there any where that sell these ? Found a nice set off winters but fit E70
PREV-
Ford Focus ST3
Post by X5Sport » Sun Sep 16, 2018 12:53 pm
You’ll need to know what the differences are and then look on eBay etc for spigot rings,
