Winter wheels / tryes for the X5M
Posted: Fri Sep 07, 2018 4:32 pm
by pvr
Anyone know what will fit? Bit different from the E53 and E70 models I have had where there were lots and lots of choices by just picking a set of 'SE' wheels of the same model.
The M seems a bit "special" that it probably means that I can't get away with a standard set of wheels as the rims have to be 20" for starters.
Any wheel gurus that can advice on what will work without issues?
Re: Winter wheels / tryes for the X5M
Posted: Fri Sep 07, 2018 4:42 pm
Have a look on Realoem under ‘Retrofitting’ as it lists the specific sets for winter against your VIN.
Check that TPMS and SSR (runflat tyres) are fitted too.  Some sets don’t use SSR or RFT tyres but all should have TPMS - assuming you car has the wheel sensors on them?
Posted: Fri Sep 07, 2018 4:59 pm
by pvr
Thanks - will do that.
Will have to check on the sensors, not sure about that.
Posted: Fri Sep 07, 2018 6:03 pm
If the tyre pressure warning system on the iDrive gives you pressures per wheel, you have TPMS sensors on each wheel.
Jan 2018 builds have this set only.
Non-run flat but with TPMS....Style 611M
https://www.realoem.com/bmw/enUS/showpa ... Id=03_4474
Posted: Fri Sep 07, 2018 6:21 pm
by pvr
£4000  :'(
Let me set up a crowd funding page on xdrivers  :))
Thanks as always X5Sport
Posted: Fri Sep 07, 2018 9:44 pm
by mogsyman
We have bugger all snow down here so don’t be a big girl and just drive it on normal wheels and tyres  :))
Posted: Fri Sep 07, 2018 10:03 pm
£4K......hmm about an hour of your time then  :P
BMW want £2k for the 220xD Gran Tourer set - and that’s through this ere Forum (cheers guys at Coltswold, I am considering it).
Posted: Fri Sep 07, 2018 10:33 pm
by pvr
[quote="mogsyman"]
Skiing, I use the jeep for the UK.
