				Windscreen break......aaaarrrrggghhhh!
				Posted: Sun Mar 27, 2011 5:48 pm
				by x555
				Just my run of luck lately
  we have had a small stone chip in the screen for a while now so i knew at some point that it could get worse and need replacing and then yesterday the crack came
Checked my insurance and we are covered for windscreen damage
  so just have to pay the first £65 and then job done.
Windscreen blokey is coming tomorrow afternoon....... man thats a big screen when you look at it
  i guess it would cost a two or three hundred £££'s to replace that sucker.
I was thinking of selling the x but at this rate i will have that many new parts i will virtually have a new car
				Re: Windscreen break......aaaarrrrggghhhh!
				Posted: Sun Mar 27, 2011 5:51 pm
				by Minda
				Well you dont need my kind of luck had mine changed on the van a few years ago, and got a chip in the new one 2 days later
				Posted: Sun Mar 27, 2011 6:23 pm
				by ianmaney
				I remember picking my X up a few years ago, got it maybe half a mile from the stealers and the car in front flicked a stone up and cost me a wind screen, hadn't even got it home !!!
				Posted: Sun Mar 27, 2011 6:26 pm
				by Minda
				Thought it was just me
				Posted: Sun Mar 27, 2011 8:10 pm
				by jango-fett
				my bonnet opened at speed and broke mine.....
£75 excess...
				Posted: Sun Mar 27, 2011 8:49 pm
				If you have auto wipers/lights, make sure they arrive with the right version before they cut the old one out.  I had a screen change four years ago and the repairers turned up with a screen with the wrong shaped detector fitting on the screen.  Unfortunately the fitters removed the old screen before they spotted it.  One of them scraped the lens off the screen and lo and behold the auto lights/wipers stopped working.  My insurers paid for BMW to do the job properly @ £700!  Car was under warranty at the time and it turned out that if a non-OEM screen was fitted by anyone other than BMW then the paint and interior warranty was invalidated!!
				Posted: Mon Mar 28, 2011 4:53 pm
				by x555
				Posted: Mon Mar 28, 2011 5:20 pm
				by Powercat
				Now you can sing
"I can see clearly now, the cracks is gone,
I can see all obstacles in my way
Gone are the dark clouds that"---------- etc
Did you see the process he use to remove the old windscreen, I am asking this as one day I might have to do my own,
no windscreen cover with my insurance
				Posted: Mon Mar 28, 2011 7:37 pm
				by x555
				[quote=""Powercat""]Now you can sing
Yes i pretty much saw the whole process and there were quite a few bits to come off but it looked fairly straight forward,but then he did have all the gear for the job mind and obviously does it day in  day out
Given the correct tools and proper sealant i would be confident enough to take this job on however with the screen costing in exess of £300 (if bought new that is
 )it makes sense to add it to the insurance and pay the £65 or so exess.
				Posted: Mon Mar 28, 2011 8:06 pm
				by Sanj
				Good Jooooob!
Cleanest bit of the car, since you've owned it!
				Posted: Mon Mar 28, 2011 8:18 pm
				by 5hep
				Glad its sorted
Finally a clean bit on your X
				Posted: Tue Mar 29, 2011 7:27 pm
				by PhilT
				[quote=""x555""][quote=""Powercat""]Now you can sing
 )it makes sense to add it to the insurance and pay the £65 or so exess.[/quote]
It's a relatively straightforward process, as you say if you have the right tools - i.e. a window removal tool, long bladed knife (craft type), cheesewire and the correct primer, adhesive etc.  I've replaced quite a few ranging from HGV's to 911's and the key is taking care when cutting the old screen out - it's easy to damage trim or slice through a hidden cable.  Putting the new one in is the easy bit (as long as you don't drop it
				Posted: Tue Mar 29, 2011 8:55 pm
				by Pewters
				[quote=""Sanj""]Good Jooooob!
You can talk!!!!!.....you've had a dustbin lid stuck under the front of yours for months and still not removed it LOL
