new x pipe :)
Ryoken
new x pipe :)
just got the x pipe fitted on the shed, will post pics and a video later.
not too loud, not a great deal of droning , and on certain revs its near silent
got to get used to it , as it IS louder than my origional
2002 e53 4.4 tempremental
- henrym3
Re: new x pipe :)
Is it just louder or is it more V8’y, aren’t they sopposed to free up more power? If so is it noticeable. Or, as in most cases because it’s louder one gets the impression it’s quicker.
VW R32 Gone
VW R32 Gone
themoog
Re: new x pipe :)
I'm contemplating getting a H pipe instead of the fat box in the centre of the exhaust- doesn't it have an X pipe inside it anyway?
I want a deeper V8 burble like our L320.
An X pipe gives more power in high revs but less torque in low revs whereas a H pipe is opposite. Allegedly.
Ryoken
Re: new x pipe :)
dunno , ill let you know when i get the thing repaired
ac belt got loose and eat through a lower coolant hose, number 3 on the realoem diagram i think
https://www.realoem.com/bmw/enUS/showpa ... Id=11_2855
so im parking it off.
i know ive gone from 14mpg to 19mpg though which is a bonus
- henrym3
Re: new x pipe :)
Surely 5 mpg can’t be down to just an X pipe, you must have done something else, plugs, coils?
VW R32 Gone
VW R32 Gone
- Greydog
Re: new x pipe :)
Henry come on, he's driving slowly with the window down listening to the noise?Easy to get 5mpg that way.
- henrym3
Re: new x pipe :)
Of course, how stupid f me
VW R32 Gone
VW R32 Gone
Ryoken
Re: new x pipe :)
nope , no new plugs , no new coils, just exhaust, ill post an update when it comes back on the road
Ryoken
Re: new x pipe :)
so today, I stripped the front end of the engine down to get to the little pipe,
air box, fan , all coolant pipes, thought to myself look at all the thick crud on them upper timing cases, so I degreased the entire engine , then blasted it so now I got a nice clean sparkly front of engine. should be able to see where oil leaks coming from,
i checked all my pulleys they were fine, AC made a noise when you span it , but nothing else,
then everything went down hill.
i spun the water pump and i dont know why but i tried moving it side ways, and yeay, there was sideways movemt and a nice unwelcoming click when you did it, great new waterpump , checked receipts its 4 year old
so then thoughtt ill take it out ready for next week ,
so undid the screw on the waterpump and the little nut on the right hand side , and the damn pipe fell out
http://www.new-part.com/sites/default/f ... 0151_0.jpg
the little tab on the left has broke off, and looking at it it the left side looks a bit battered,
so new one of them bought aswell,
so loads of new bits ordered ,
so i wont get to drive it for a bit longer, i dont get why when you spend loads of brasssto "treat" a car, she then pays you back by breaking loads of bits !!
- henrym3
Re: new x pipe :)
Maybe all that crud was holding everything together. Better to find that stuff at home than on the road. If the front of the engine is/was covered in crud and it isn’t visibly coming from the cam cover then it will be the solenoid valve seals/gasket. If you could pin down where it’s weeping it would be easier to do whilst in there.
VW R32 Gone
VW R32 Gone
Ryoken
Re: new x pipe :)
well, the plan is, refit everything together, just fill cooling system up with water, run it for a bit to get it all nice and warm , and let the oil get everywhere, then , remove whats necessary to have a proper look at the front of the engine , then replace whats needed.
there did seem to be alot of crud round the solenoid gasket area.
but we shall see
but we shall see
Ryoken
Re: new x pipe :)
She lives
new water pump , new other stuffs, only filled it with water at the mo as I'm going to run it for a week or 2 to find the mysterious oil leak on the front end , then it will be getting stripped down again ,
no leaks, so its all good,
I took it easy on the way home , 20 miles , average 19 mpg
happy days, having a celebratory beer
Re: new x pipe :)
Sounds good. Don’t leave it too long before adding corrosion inhibitor/coolant though. You don’t want a rusty engine after all of the work you’ve just done
Ryoken
Re: new x pipe :)
no I don't plan on it ,
ive bought all the upper timing case gaskets, , and the solenoid ones, cos I was at the dealers,
believe it or not the dealers near me was ALOT cheaper than the normal ebay ones, didn't think of that tbh
its going to be run it for a bit , and see which gasket or seal is leaking , then strip, then rebuild.
THEN....
ill post pics and vids of the xpipe and the zorst., . but it wont be for a few weeks
THEN....
- henrym3
Re: new x pipe :)
Must admit I always use the dealer as a reference point, money wise, they do well on parts and if there’s only a few £’s in it I use the dealer. Labour is a whole different ball game.
Looking forward to pics and hope you find the oil leak.
VW R32 Gone
VW R32 Gone
