Cv joint removal
Zedhed
Cv joint removal
Hi folks,im trying to change the outer cv boot but cant see how the cv joint comes off to get the boot on.is there a clip or summat.
Re: Cv joint removal
Found this might help.
""remove the clamp bands from boot .
hold axle shaft , keep pressure on it toward inner boot whilst you hit outer cv joint away from shaft , by now you will realise the need for assistance""
https://xoutpost.com/bmw-sav-forums/x5- ... nutes.html
Zedhed
[quote="Alan Gunn"]
[/quote]Thanks alan.dident need to remove axle from gearbox then did i[emoji53]
Sent from my LG-M160 using Tapatalk
