Start up
pcdee
Start up
Post by pcdee » Wed Jul 04, 2018 7:52 am
Morning
Occasionally she takes a little while to start up.  Keeps turning over bit eventually she starts.
I ran Carly and it came up with;
004B90 (Rail pressure monitoring at engine start)
Also please see attached of other issues which could be linked or completely different
X5 E70 3.0D SE
Re: Start up
Post by Alan Gunn » Wed Jul 04, 2018 8:11 am
I had the rail pressure on starting code.
My car would crank over a few times and then start when cold but would take a lot more cranking when hot.
It turned out to be 2 injectors leaking badly new ones fitted and it starts straight away hot or cold.
Get a leak off test done on them it's the only way to tell.
pcdee
Re: Start up
Post by pcdee » Wed Jul 04, 2018 9:29 pm
I will get it booked in for the test.
I thought I'd take a look at the injector price and boy are they expensive.  £350 for 1!!
Sent from my SM-G900F using Tapatalk
X5 E70 3.0D SE
Re: Start up
Post by X5Sport » Thu Jul 05, 2018 6:48 am
Expensive they are indeed.  You can get 1/3 off at ECP though using code SUMMER33 at the moment though.
Re: Start up
Post by Alan Gunn » Thu Jul 05, 2018 6:50 am
[quote="pcdee"]
That is very expensive you can get manufactures refurbished for around £100 or even less.
can't find my invoice but i had mine done last year.
The test 2 injectors coding and fitting was around £400 or a bit under not main dealer but a good bmw specialist.
Shop around.
jason@bwchiptune
Contact:
Re: Start up
Post by jason@bwchiptune » Thu Jul 05, 2018 7:39 am
If your near west London we can have a look and test it for you
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
Sent from my iPhone using Tapatalk Pro
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
pcdee
Re: Start up
Post by pcdee » Thu Jul 05, 2018 7:44 am
[quote="Alan Gunn"]
[quote="pcdee"]
Shop around.
[/quote]Thanks.....I take it refurbished ones are fine
X5 E70 3.0D SE
pcdee
Re: Start up
Post by pcdee » Thu Jul 05, 2018 7:45 am
[quote="jason@bwchiptune"]
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
[/quote]I would love to come up to you but I'm in Canterbury so it will be a bit of a mission.
Thanks for the offer though
X5 E70 3.0D SE
pcdee
Re: Start up
Post by pcdee » Thu Sep 13, 2018 9:33 pm
All 6 injectors need replacing......just my luck
Being charged £165 + vat for each one
X5 E70 3.0D SE
Re: Start up
Post by Alan Gunn » Fri Sep 14, 2018 8:45 am
[quote="pcdee"]
I feel your pain.
pcdee
Re: Start up
Post by pcdee » Fri Sep 14, 2018 3:57 pm
Garage just phoned....all done!!
Picking it up tomorrow  £1624 all in
X5 E70 3.0D SE
