I'll be doing a long road trip in France and need to convert lights to LHD. I have heard this can be done at the flick of a switch but need to take out the front light cluster, which sounds like a pain to do roadside!
Am I just better off getting those stickers?
Driving in France - switching to LHD lights
Re: Driving in France - switching to LHD lights
If you have active xenons, I believe there is a setting in the idrive for it. Not checked on mine though.
Mike
Mike
2012 X5 40d - Loving it..
Z4 3.0 - With LOTS of mods ::)
#TheZedShed
#TheZedShed
I could be wrong - most likely I am
However, if you switch the lights to Auto, the beam pattern flattens, good for either side of the road!
I thought 'Auto' was for auto on/off according to the light conditions?
Not checked the iDrive menu - Mrs has taken car out, but don't recall ever seeing the option...
Some people are talking about a switch in the cluster - will check that too
Apparently after doing a bit of reading, no change required as the adaptive xenons have a flat beam pattern. Will check in the dark tomorrow
Whilst checking “in the dark”
Switch between Auto and position II
You should notice the shutter open and close to give directional pattern or flat beam
It helps if you drive up to a wall
Hence once you’ve jumped the pond use Auto lights only
Well the Auto and 0 position have a flat pattern and the setting at the end of the dial is a dipped pattern. I guess the flat pattern on Auto is fine then!
