DIY Key Replacement
Posted: Sun Jun 17, 2018 3:15 pm
Hi guys
Finally making good progress with the X5. Engine running well following timing chain and VANOS Work. Got the steering recalibrated after error messages from LEW sensor, seems to have fixed that and Westfalia towbar fitted.
Next up, I only have one original key, which barely works, very intermittent using the buttons, suspect the micro-switches are goosed. I note from eBay that they can be fairly inexpensively repaired, but involves posting them off for a few days which for me renders the car useless!
So alternate plan, have seen on YouTube that you can get a Key Programmer (AK90) from eBay inexpensively, £25, which enables you to reprogram a new eBay aftermarket key, Timpsons quoting me a fiver to have it cut.
BMW quoting me £161 plus VAT for a new key and a local locksmith quoted me £120, but didn’t turn up twice. So time to try it myself? Should be able to do it for circa £40. Anyone had a go at this? Believe the trickiest part which isn’t too difficult is getting the EWS module out of the car. Located in the drivers footwell..
