Page 1 of 2
Non start problem
Posted: Sat Jun 16, 2018 12:31 pm
by Jameth1980
As title, car won't start was driving fine pipes into the shop for 10mins came back and wouldn't start. Fuel gauge reading a quarter I've pit in 2 Jerry cans to see if that would help no difference, been read only code we got was 1e25 monitoring, speed sensor any help would be appreciated as it's been sat in Aldi carpark since Tuesday
Re: Non start problem
Posted: Sat Jun 16, 2018 6:48 pm
by marti
Petrol or diesel engine?
Posted: Sat Jun 16, 2018 6:57 pm
That error code seems to be connected with the crank sensor which will stop the engine starting.
Posted: Sat Jun 16, 2018 7:00 pm
by Jameth1980
Sorry diesel, yeah that's what I thought so changed it out cleared codes and still won't start and code logged again
Posted: Sat Jun 16, 2018 8:06 pm
by Alan Gunn
I would try the cam sensor very easy to change(front end of the rocker cover).
Posted: Sat Jun 16, 2018 8:53 pm
by Jameth1980
Thanks but that was changed a couple of months ago
Posted: Sun Jun 17, 2018 8:32 am
by marti
[quote="Jameth1980"]
Were both the sensors genuine?....as you still have the code coming up for crank sensor if it is genuine BM automatically give a two year guarantee....
Posted: Sun Jun 17, 2018 8:39 am
by marti
This might be worth a punt....spray a big load of easy start in the intake box and try starting it...better if there's two of you one spraying and one starting...if it does fire up its an injector problem...if not your back to that crank sensor.....
Posted: Sun Jun 17, 2018 8:47 am
by Jameth1980
Just had the injectors done as had fuel pressure fault, new line pump aswell, tried the easy start would get a rumble but die again. Genuinely if this wasn't sat in a carpark surrounded with cameras I would torch the heap of shit it's had problem after problem
Posted: Sun Jun 17, 2018 9:01 am
by marti
So is the crank sensor a genuine one or a cheapo off ebay etc....
Posted: Sun Jun 17, 2018 9:20 am
by Jameth1980
It's a febi from my local parts shop
Posted: Sun Jun 17, 2018 5:09 pm
by marti
Should be okay then....have you checked the fuses?
Posted: Sun Jun 17, 2018 6:24 pm
by Jameth1980
Checked all the ones I could find which one and where is the specific one for that?
Posted: Sun Jun 17, 2018 8:41 pm
by marti
There is no specific fuse for the crankshaft sensor....as it stumbled with easy start Im thinking its fuel supply thats the problem.....
Posted: Sun Jun 17, 2018 8:59 pm
by Jameth1980
It's just a heavier sound when you turn it over not really close to starting there's fuel coming through the filter, had it on inpa 3.7 bar pre supply 375 high pressure when turning over
