Non start problem
Jameth1980
Non start problem
Post by Jameth1980 » Sat Jun 16, 2018 12:31 pm
As title, car won't start was driving fine pipes into the shop for 10mins came back and wouldn't start. Fuel gauge reading a quarter I've pit in 2 Jerry cans to see if that would help no difference, been read only code we got was 1e25 monitoring, speed sensor any help would be appreciated as it's been sat in Aldi carpark since Tuesday
Re: Non start problem
Post by marti » Sat Jun 16, 2018 6:48 pm
Petrol or diesel engine?
Post by X5Sport » Sat Jun 16, 2018 6:57 pm
That error code seems to be connected with the crank sensor which will stop the engine starting.
Jameth1980
Post by Jameth1980 » Sat Jun 16, 2018 7:00 pm
Sorry diesel, yeah that's what I thought so changed it out cleared codes and still won't start and code logged again
Post by Alan Gunn » Sat Jun 16, 2018 8:06 pm
I would try the cam sensor very easy to change(front end of the rocker cover).
Jameth1980
Post by Jameth1980 » Sat Jun 16, 2018 8:53 pm
Thanks but that was changed a couple of months ago
Post by marti » Sun Jun 17, 2018 8:32 am
[quote="Jameth1980"]
Were both the sensors genuine?....as you still have the code coming up for crank sensor if it is genuine BM automatically give a two year guarantee....
Post by marti » Sun Jun 17, 2018 8:39 am
This might be worth a punt....spray a big load of easy start in the intake box and try starting it...better if there's two of you one spraying and one starting...if it does fire up its an injector problem...if not your back to that crank sensor.....
Jameth1980
Post by Jameth1980 » Sun Jun 17, 2018 8:47 am
Just had the injectors done as had fuel pressure fault, new line pump aswell, tried the easy start would get a rumble but die again. Genuinely if this wasn't sat in a carpark surrounded with cameras I would torch the heap of shit it's had problem after problem
Post by marti » Sun Jun 17, 2018 9:01 am
So is the crank sensor a genuine one or a cheapo off ebay etc....
Jameth1980
Post by Jameth1980 » Sun Jun 17, 2018 9:20 am
It's a febi from my local parts shop
Post by marti » Sun Jun 17, 2018 5:09 pm
Should be okay then....have you checked the fuses?
Jameth1980
Post by Jameth1980 » Sun Jun 17, 2018 6:24 pm
Checked all the ones I could find which one and where is the specific one for that?
Post by marti » Sun Jun 17, 2018 8:41 pm
There is no specific fuse for the crankshaft sensor....as it stumbled with easy start Im thinking its fuel supply thats the problem.....
Jameth1980
Post by Jameth1980 » Sun Jun 17, 2018 8:59 pm
It's just a heavier sound when you turn it over not really close to starting there's fuel coming through the filter, had it on inpa 3.7 bar pre supply 375 high pressure when turning over
