x3 e83 4b90 fault code non starter 3.0d :-(
Posted: Mon Jun 04, 2018 2:29 pm
				Hi all i am the now not so proud owner of an x3 3.0d, to be fair its been reliable for the last 10000 miles since i bought it.
It all started with my dde light coming on a couple of times while driving from work, then on the way to work it came on and would not go out unless i deleted the code with my scanning tool. I managed to drive to work with the scanning tool on my lap deleting the code everytime the light came on thus keeping the car from conking out. A day later trying to limp the car home it completely died going down a hill and came with a second code 4B90.
I have changed the throttle body and egr unit and solved the first issue but i am very stuck on the second.
So far i have found that fuel is getting to the pipe that connects to the fuel rail but will not get past the fuel pressure regulator unless i loosen it from the back of the rail ( i have changed the preesure regulator but still no joy,
with it loosened fuel fills the rail and fuel pipes for each injector but will not fire or try to.
Any help of where to start would be great ( could it be injectors failing ) ? i am at a loss thanks
