Tyres on Mini
marinaman
Contact:
Tyres on Mini
Post by marinaman » Sun May 27, 2018 10:41 pm
Evening all
Hope in right place.
Bought daughter a Mini clubman 2010 for her 21st birthday in few weeks,  hiding it at moment and going through it.
Came from a one owner with full history, however, checking tyres today and missed when i inspected before buying, althogh all good tread tyres i missed the obvious
3 tyres are Pirelli run flats,  but found on the front axel a standard tyre. Never had run flats so only now know they are marked run flat  etc etc
Done some web search and seem to find its not a good idea but mixed opinion if its actually legal.
Im going to get a run flat on asap.
have spoke to owner who said took and told garage to MOT it last Feb and put a tyre on,  the owner said they didnt know it was not a run flat and maybe the garage got muddled. !!!!!    i dont know if they lying or not  but would have expected the garage to know and not fit a run flat and non run flat on same axel.
Other question.  The tyres are a mix,
i have Pirelli P ZERO on the drivers side front and rear,  but a Pirelli Centuro P7 run flat on the rear axle passenger side and this chinese tart on the front.
should i have a  PZERO and P7 on same car and same axle , or should i replace the cheepo with another P7 and match them on the rear or front axel and the PZERO on other axel.  Or should i replace the cheepo and P7 with Pzero  so i have them all round
getting myself mixed up as well  :rofl: :rofl:
Re: Tyres on Mini
Post by X5Sport » Mon May 28, 2018 1:03 pm
Legally:
The law says; “That tyres have to be the same nominal size and aspect ratio(profile) on a given axle.”
Mixing types is not an ideal situation, but not illegal.
I have had P7 and P0 tyres and the 7s lasted longer, but the P0 gave more grip in the dry - probably a softer tyre?
marinaman
Contact:
Re: Tyres on Mini
Post by marinaman » Mon May 28, 2018 4:06 pm
Thanks ,  knew i would get right advice on here.
So would it be best to replace the cheepo with a P7 then  i have two  P7 and  two P0,  i presume this is a safe set up , but are there preference as to which ones at front or rear.  ideal woud be all same tyre but too much good tread at moment on all the 3 run flats.
Not making this a Mini forum chaps but was worried when saw this Cheap non run flat type on with the rest.
Re: Tyres on Mini
Post by X5Sport » Mon May 28, 2018 5:05 pm
Mini being front wheel drive should have the best tyres on that end.
Technically a Mini is a kind of BMW (but don’t tell the purists on here  O:-) )
