intermittent Braking/engine surging going down hills
couchiedemon
Post by couchiedemon » Wed May 09, 2018 12:59 pm
Quite often, when doing down a steep hill, having taken my foot off the accelerator, the brakes will be applied and the engine will rev to approx 4000 RPM. Someone has said that this is a "feature" akin to pre-emptive braking but to me it seems like problem as it doesn't happen all the time and does not seem to be related to the traction control (in that no traction control light comes on when this happens. Blipping the throttle seems to cure it - as the braking effect ceases and the revs return to normal. Any ideas? Car is a 2002 3.0i with 76k miles on the clock.
2002 E53 3.0i, 2005 Mini Cooper S Conv,  Honda NC750X
Murphybarnes
Re: intermittent Braking/engine surging going down hills
Post by Murphybarnes » Wed May 09, 2018 8:36 pm
Forgive my ignorance but I wasn't aware that E53 had traction control. Never once felt the brakes being independantly applied.
I do get the rev surge when going down a decent hill though.
Engine braking I presumed.
2006 3.0d Le Mans.
Post by Horizon » Wed May 09, 2018 9:53 pm
It's normal for the E53 to do this is is engine braking. The gearbox / DSC system monitors down hill conditions and if you need to press the brake to hold the desired speed it changes down and hold the desired speed under engine braking as you would in a manual to save cooking the brakes.
And yes DSC is traction control.
Richyroos
Post by Richyroos » Sat Jun 02, 2018 11:05 am
Ditto the above! The amount of engine braking depends on how hard you step on the brakes, so it will vary each time, a heavy braking application will drop the gearbox down two gears instead of the usual one. Applying the accelerator changes back up again.
If in doubt, and all else fails - read the instructions!!  :) :)
Current car : 2004 E53 X5 3.0D
Zedhed
Post by Zedhed » Wed Jul 25, 2018 2:43 pm
I still have trans fail safe come on when going down certain hills.very odd.[emoji53]
Sent from my LG-M160 using Tapatalk
fenj66
Post by fenj66 » Wed Jul 25, 2018 11:19 pm
[quote="couchiedemon"]
i think thats normal,
if i remember correctly, pressing the dsc button will turn off this feature.
Post by marti » Thu Jul 26, 2018 7:03 am
All very normal....most automatics do this..
Post by henrym3 » Thu Jul 26, 2018 8:14 pm
I know I have a different engine but mine doesn’t do anything that sounds as aggressive as you suggest yours does. You can feel it hold back a bit if your foot is off throttle and it will change down but only when at a speed that is appropriate. If hill is steep (on road) it will pick up speed again unless brakes are applied.
VW R32 Gone
