To do list
DaveRob
To do list
Post by DaveRob » Tue May 01, 2018 10:29 pm
I guess most of us here have a to-do list of jobs on the X5.
Here's mine.
Fit new front suspension components, hopefully to eradicate the horrendous braking wobble. I have the parts, and should be done within 2 weeks.
Fit new brake discs and pads, if the above doesn't work.
Fit a switched power supply behind the stereo to supply my dash cam and dab receiver, to stop the battery going flat if I forget to unplug them.
Remove the chrome on the front grilles.
Fix the pixel problems on the radio and the dash.
Fix the occasional three yellow lights problem, I guess by replacing an abs sensor.
Fit springs to open the tailgate fully when I press the dash or remote button.
Change the running boards to black (think this will look good on a black car)
Fit black, or at least smoked, rear lights.
I'm sure there's more, and the priority will change on some, but that'll do for now..
What about you?  Do you have a list?
DaveRob
Re: To do list
Post by DaveRob » Tue May 01, 2018 11:02 pm
Just remembered..  fix parking sensors! I have two at the front not working.
marinaman
Contact:
Re: To do list
Post by marinaman » Wed May 02, 2018 8:40 pm
watch them springs for the tailgate.  i dont if there are different types,
i saw a You tube vid from the USA and a link to order,  took 2 weeks and worked great for a while but now they just about manage to pop it up half way if that.
I reckon needs a stronger spring, anyone got any info on this,  mine are only around 8 months old and not had a lot of use so a bit let down by our US pals.
Colin
Re: To do list
Post by Colin » Wed May 02, 2018 8:58 pm
was thinking of them springs aswell  but now i'll wait
05 , 30d Le Mans Blue Sport
hennabm
Re: To do list
Post by hennabm » Wed May 02, 2018 9:40 pm
A to do list;
Seat module replacement
BM54 repair/upgrade
OSF door carrier replacement
New battery
New key
Tailgate switch to replace
Upgrade headlamps
Cure engine oil leak
Clean leather upholstery
Apart from this, not much this year.
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
DaveRob
Re: To do list
Post by DaveRob » Wed May 02, 2018 10:01 pm
[quote="marinaman"]
I just found some springs at work, I mean lying about on the street, and tried them. Not quite right, but it did make me realise that my gas struts are past their best.  I think with new struts they may work. It's low on my priority list at the mo!
marinaman
Contact:
Re: To do list
Post by marinaman » Thu May 03, 2018 4:03 pm
ahhh    never thought my struts maybe worn  though they hold up the tailgate normally.
Would i be right in thinking    newer stronger struts would push it up further or the opposite and make it more difficult for the springs  :weakbench:
DaveRob
Re: To do list
Post by DaveRob » Fri May 04, 2018 10:26 pm
I thought my struts were ok, until I fitted the springs. Removing one strut, and the boot lid wasn't even close to supporting itself with just the one strut in place.  I think it should have at least had some effort at holding.
Guess my struts are on their way out. Hardly surprising,  as they're 15 years old now.
New struts will work with the springs, and aid the lifting of the tailgate.
Silverfox58
Re: To do list
Post by Silverfox58 » Mon May 07, 2018 6:46 pm
Hi I have a set of rear lights for sale if interested
X5 30d
Re: To do list
Post by henrym3 » Tue May 08, 2018 7:48 pm
I have the rear strut springs fitted, they came with some washers/spacers to increase the spring tension and they work well, only on the coldest days, like -c temperatures do they struggle to open the tailgate. I do intend to replace the struts this year with the ones sold by SGS Engineering which seem to have good reports.
VW R32 Gone
A Blair
Re: To do list
Post by A Blair » Tue May 08, 2018 8:29 pm
Hi DaveRob,
With regards to your runner boards I hope you post up a thread. As its aluminium (I think) it might be possible to anodise them or did you have another path in mind like powder coat.
X5 E53 2005 4.4 Sport. Toledo Blue
Things to consider.
Radio. (something in
Detail Car.
DaveRob
Re: To do list
Post by DaveRob » Thu May 10, 2018 6:28 pm
Ooh, anodised them? Hmm, hadn't thought of that, but that could be a great idea!  It'll be a while before I get to that item on my list, but I'll keep you posted...
