				2005 X3 E83 2.0d DSC fault code
				Posted: Mon Apr 30, 2018 11:49 am
				by kampftrinker
				Hi,
I'm down to one last fault code on my car. the error code is 005F1E and it appears to be something to do with the dynamic stability control.
The fault explanation (from Carly) is "disabled trailer roll logic about EEPROM: variant coding: info entry"
Does anyone have any idea what this means, or what the problem could be? There are no warning lights and the car drives fine.
Mick
				Re: 2005 X3 E83 2.0d DSC fault code
				Posted: Mon Apr 30, 2018 6:16 pm
				Have you got a towbar?  It could be the additional functionality that turns on when a trailer is plugged in as the trailer changes how the DSC works.
				Posted: Mon Apr 30, 2018 6:32 pm
				by Alan Gunn
				Would not having the towing module fitted and a trailer being plugged in.
Just thinking somebody might have done a DIY job fitting a tow bar and not fitting one.
Could well be miles off but just a thought.
				Posted: Mon Apr 30, 2018 8:13 pm
				by Horizon
				[quote="Alan Gunn"]
I fitted a Westfalia E83 dedicated tow bar electrics to my old E83, only the dedicated kit has a green wire that runs up to a module at the rear of the dash, It syncs with the DSC and prevents the rear parking sensors from working when a trailer is coupled to the car
Has it got a tow bar fitted.
If so check if it has a wire from the trailer electrics box, sited near the battery in the boot.
				Posted: Tue May 01, 2018 7:17 am
				by slparry
				Perhaps it's not been wired correctly for Trailer Stability Control
".........The new BMW X3 is able to tow a trailer weighing up to 2,000 kilos or 4,410 lb.
And to ensure maximum safety in such a situation, BMW’s SAV is equipped
with innovative Trailer Stability Control suppressing any dangerous instability
and preventing the combination of vehicle and trailer from developing a kind of
pendulum sway.
Trailer Stability Control recognises such a risk at an early point in time and
quickly applies the brakes on both the vehicle itself and the trailer to avoid any
pendulum action. The system also briefly reduces engine torque to a minimum,
providing both functions without any intervention on the part of the driver.
Trailer Stability Control is activated automatically when the trailer is connected
to the vehicle by the power cable and intervenes at a speed down to 65 km/h
or 40 mph........"
				Posted: Tue May 01, 2018 8:58 am
				by kampftrinker
				Thanks for the replies,
The car doesn't have a tow bar fitted, not sure if it has had one in the past.
I did read on another site that someone had the same code fault and was advised that it was the ABS speed sensors. I plugged a Foxwell code reader into it yesterday evening as they can read the live ABS speed sensor data, they all appeared fine. The interesting thing was I ran the diagnostics and it showed no faults!
So Carly shows a fault and Foxwell doesn't, I'd rather believe the Foxwell reader as it means I've got nothing to fix lol. As I've got no warning lights on the dash maybe that's the case.
Mick
