F15 Tow Bar - dealer fit?
Posted: Wed Apr 25, 2018 12:02 pm
by PaulD
I am just changing my E70 after 5 years and 120k miles. I have put a deposit down on a 65plate F15 4.0D MSport which we love. However the dealer is charging me £2,500 for an electric towbar or £2,050 for a standard detachable towbar.
The detachable bar we put on the E70 by an independant fitter was £650 and used all BMW parts.
Is the dealer overcharging or is this true cost for a dealer?
Many thanks
Paul
Re: F15 Tow Bar - dealer fit?
Posted: Wed Apr 25, 2018 1:55 pm
by mogsyman
I would go with a Jones towbar - they use Westfalia which are identical to the BMW manual bars and as you say are £600 or so to fit.
Job jobbed.
Posted: Wed Apr 25, 2018 3:59 pm
by IanP
Maybe that includes cooling system upgrade?
Posted: Wed Apr 25, 2018 6:37 pm
From memory, the retrofit is called up from a Dealer parts menu which says something like 12 hours to fit.
The official retrofit is mainly labour as they take half the car apart.  Necessary if you really want a BMW warranty, but very expensive considering it’s almost the same parts.  I’m sure aftermarket with the OEM parts is just as good.
Posted: Wed Apr 25, 2018 10:28 pm
by mogsyman
Prior to having mine fitted I confirmed with the dealer it would have no implications on the BMW warranty.
Posted: Thu Apr 26, 2018 12:32 pm
by PaulD
Thanks all for the advice - much appreciated. Will go with local firm I have used before but also check on the warranty.
Posted: Wed May 09, 2018 9:53 pm
by BullyB
I had my E70 and F15 detachable hitches installed by PF Jones
No issues and good value
Posted: Wed May 09, 2018 10:00 pm
by Dogzyboy
[quote="BullyB"]
They’re doing mine in a couple of weeks too.
Posted: Tue May 15, 2018 4:35 pm
by elliot330
I'm pretty sure the dealer has to fit a new torque converter and bigger electric fan. Hence the cost and time
Posted: Tue May 15, 2018 5:54 pm
Radiator maybe, but torque converter?
Posted: Tue May 15, 2018 8:11 pm
by elliot330
Just checked and my bad. Its just the electric fan that needs swapping. Not sure where I got the torque converter bit from sorry :-[
