				LCI 2012 sports front coil spring broke at 45k?
				Posted: Tue Apr 24, 2018 10:07 pm
				by Aby1
				Driving along this afternoon, and there was a very loud bang, pulled over and the front driver side spring has broken, is this part covered under the Bmw comprehensive insured warranty? There's no mention in policy about suspension, But at the same time it doesn't say it's not covered.
				Re: LCI 2012 sports front coil spring broke at 45k?
				Posted: Wed Apr 25, 2018 6:44 pm
				Our E46 breaks rear springs regularly, and usually in that spot at either the top or bottom final coil too.
I even had a Dealer once tell me that it was down to BMW using ‘recycled steel’!
The chances are that there was a microscopic inclusion or defect that caused a minute crack and over time it has fatigued.  You would need electron microscopy to find it though.
				Posted: Wed Apr 25, 2018 8:53 pm
				by alan996
				[quote="Aby1"]
[/quote]As long as you are under the mileage limit for wear and tear (100k miles I think) then yes..I had one replaced earlier this year under warranty
Sent from my Pixel 2 XL using Tapatalk
				Posted: Wed Apr 25, 2018 9:02 pm
				by gmc15
				One of mine went at about 40K on the front. I did not have a warranty but got a new spring fitted at a local garage for a very reasonable cost.
				Posted: Thu Apr 26, 2018 11:47 am
				by Aby1
				Thanks guys, Dropped car off this morning at JCT BMW Bradford will let you guys know how I get on
Sent from my ONEPLUS A3003 using Tapatalk
				Posted: Fri Apr 27, 2018 6:46 pm
				by Aby1
				Update got car back today replaced OSF coil spring and both thrust arms and carried out 4 wheel alignment, total cost was over £1100 good job I had a BMW warranty in place worth its weight in gold, when something goes wrong
