Noticed recently that blowers were making a noisy whining sound, but not that loud. Recently ive had bursts where the noise has been very loud, a motor kind of noise. Also had splurts where the blower has suddenly gone really fast for a split second then back to normal.
If I manually set blower speed to maximum it seems to get rid of the noise. turning aircon on or off doesn't make any difference.
	Very noisy blowers on x5 40d
				celica
Re: Very noisy blowers on x5 40d
I have a pulsating noise from mine and not traced the issue
Pulsates or continuous changes with temp range
If it’s similar, open the bonnet and it’s even more apparent
- weaselchops
Had a similar thing on my old e46. Have a search for Final Stage Resistor (FSR)
			E70 2008 3.0sd, 7 Seats.
				asoni
I've had FSR issues in the past on E46's and am familiar with the symptoms which (as far as I know) were things like blower randomly blowing fast/slow or hot/cold by itself.
I've never had issues with the blowers making a loud motor/screeching type of noise when the FSR was faulty so I doubt it's that but will certainly look into it just in case.
- weaselchops
[quote="asoni"]
You are probably right, but I have heard of a quite different symptoms from faulty FSRs on the same model.
