Bmw x5 e53 won't change out of 1st gear
Posted: Wed Apr 04, 2018 2:18 pm
Hi new to posting help would be great full
I have a x5 e53 2002 3.0d was getting trans fail safe message
Fault that came up was steering angle so got a new 1 and I stead of putting that in and coding it I took it apart and replaced the broken part and put the original 1 back on problem fixed then the yaw sensor came up so replaced that then the fuel pump failed, replaced that now it won't come out of 1st gear so tried inpa it said no respons from gear box ecu gs19 sane for gear box control unit and dynamic stability control 4 wheel system so linked it up with Delphi cars and got a fault code 52 gear monitoring 2 permanent
