Rear suspension
Silverfox58
Rear suspension
Hi all
What to the dump yesterday with a load of wood in the car , loaded car but when I started the car the air suspension failure message came on , when to the dump and got rid of the wood , started car and no warnings, and hasn't came on again,
Now my question is do I have a rear suspension problem or was there to much weight in the car ???
The drives ok with no problems it's not down on one side , as it's done 125k could the bags be soft and need changing.
Your thoughts please
X5 30d
- henrym3
Re: Rear suspension
when you started the car at home and the warning was on did you switch off and start again like you did at the dump.
VW R32 Gone
VW R32 Gone
Silverfox58
- henrym3
Re: Rear suspension
I would put that down to a glitch, a one off, especially if you had left the key in the ignition while loading .
VW R32 Gone
VW R32 Gone
Silverfox58
X5-D-Sport
Re: Rear suspension
This is not unusual for My X5, I get this error if I have a tonnage of power hungry stuff running on start-up.
Also, you may get this if you wizz the keys straight to the starter without letting the machine do its electrical waffle & checks for 3 seconds before engaging the starter.
Additionally, if the battery is getting weak or a poor connection, the power/voltage drop can also cause a myriad of warnings too, which may / may not clear them selves by magic...
Silverfox58
Silverfox58
Re: Rear suspension
Well its back , the light has come back on so I must assume that I will have to change the air bags at the back >:(
X5 30d
Re: Rear suspension
Is the car going down at all at the rear.
Silverfox58
V8 00USH
Re: Rear suspension
[quote="Silverfox58"]
Don't assume anything - there's every chance it's the compressor instead. Check the fuses for it in the fuse panel in the back right compartment - there are 2 for it IIRC.
Silverfox58
Silverfox58
Re: Rear suspension
Ok the pump works , i added a live feed to it and it works great , no fuses blown,
It's sitting up fine, its just when I have a load on or one/two people in the back.
X5 30d
A Blair
Re: Rear suspension
I had the same 2 month ago. I did some research on a new pump. There is a site. Bagpipingandys repair kit. £25. He machines and sells the compressor ring complete with fitting instructions and parts.
The bloke is extremely helpful. Wonderful bloke.
He advised resetting the system error or the compressor would not run. I reset, and the compressor ran. I put the parts in my bottom drawer. Always handy.
If your fault has cleared the compressor will run.
I disconnected the pneumatics and let the suspension down a bit and the system started the compressor when I put the ignition up. I should add I also put my finger over the plastic pipe and the pressure was very strong.
You may well find the compressor runs shorting it out. However will the system start the compressor.
X5 E53 2005 4.4 Sport. Toledo Blue
Things to consider.
Radio. (something in
Detail Car.
Things to consider.
Detail Car.
- henrym3
Re: Rear suspension
Have you checked the leveling modules at the rear, unplug and spray with contact cleaner, plus wd40 the joints on the module arms, a little grease in the ball joints. Just cheap suggestions before spending big.
VW R32 Gone
VW R32 Gone
