Hi,
Anyone know if there any websites where I can enter the reg to get the full build spec of the new X3s?
The bmw used car search is rubbish, need to get the specs (options in particular) on the new G01 models.
The warranty checker only works on older cars, not new ones.
Any ideas, need this quick
Where can i get the build sheet spec for new X3?
sharpharp
X3driver
Re: Where can i get the build sheet spec for new X3?
Go to blue print live and register yourself for free
http://www.blue-print.com/blueprintlive/register/
Then type the reg plate and search which gives the vin.... then type the vin into this site.. which will give the full spec
https://www.bmwvin.com
sharpharp
[quote="X3driver"]
I registered, but nothing comes up when you go to the catalogue and enter the Reg. (even for older cars)
If I select the make and model from the tabs, it's only showing F25 X3 models, there is no G01 X3 model menu
Any ideas?
Any ideas?
X3driver
I just grabbed a number plate from autotrader for a G01 and worked for me.
You only need to enter a reg plate and hit enter/Go. No need to fill in any other details.
