Radio noise!! HELP!!
Posted: Fri Mar 16, 2018 3:34 pm
by Beanmasteruk
Ok, just spent nearly a grand on new turbo because of whistle in cab! Still whistling!! Took radio fuse out, fuse 73 in the boot compartment, and noise or whistle stops!! Could I fit a cheap suppressor to eliminate this, anyone know?
Re: Radio noise!! HELP!!
Posted: Fri Mar 16, 2018 5:16 pm
by sleepyfolk
No personal experience but when I was reading a lot of stereo stuff I remember the whistling or screeching as it was described was a common fault with the BM54 amp in the boot, you can send them off for repair to cartronics or similar places.
If it’s an aftermarket stereo, I don’t know!
Posted: Fri Mar 16, 2018 5:29 pm
by Beanmasteruk
That’s helpful thank you! Where is it exactly?
Posted: Fri Mar 16, 2018 5:41 pm
by henrym3
Posted: Fri Mar 16, 2018 5:43 pm
by Horizon
[quote="Beanmasteruk"]
https://www.cartronics.co.uk/BM54
Posted: Fri Mar 16, 2018 11:03 pm
by sleepyfolk
Posted: Sat Mar 17, 2018 8:48 am
by Beanmasteruk
Thank you. I’m expecting this to be the source of the problem then. It’s just a irritating low pitch whistle and when I take fuse out it stops, but no radio. Nav and tv still work though
Posted: Sat Mar 17, 2018 5:23 pm
by Beanmasteruk
I haven’t got one there???!!!
Posted: Sat Mar 17, 2018 5:37 pm
Depends upon your audio fit at build.
Posted: Sat Mar 17, 2018 11:13 pm
by sleepyfolk
That’s me out of ideas then, I thought if you had the nav/tv etc then you had a BM54 amp in the boot
Posted: Sun Mar 18, 2018 7:31 am
You should have a separate amp if that’s the case.  Have you got DSP as well?
