Hi all,
can anyone shed any light on this problem?......
I have changed the egr, new solenoid and its throwing this code again, have researched it and understand I need to take the cooler off and check its not blocked etc which I will do when weather gets a bit better.
Here lies what I have found........when I drive the car with the eml light on and the p0401 code present the mpg drops to no better than 22mpg (dotting around), if I then stop driving and clear the codes and eml light with my reader,and then reset the mpg, I get a constant average of 27mpg - 29mpg until the light comes back on again and then the mpg drops way back down again......what is happening? seems whatever is causing the p0401 is causing the car to over fuel when the code is triggered?
p.s. after clearing the code the eml light stays off for a good few miles (25+)
anyone had same?
cheers.
p0401 recirculation flow insufficient
- chelsea
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Re: p0401 recirculation flow insufficient
Everything points to the Egr was it a new one you fitted.
- chelsea
Hi Alan,
yes its had new everything.......took it for remap this morning and the difference is now like chalk and cheese, it's a different car with same power as 35d and the mpg around town has gone up from 22mpg originally to 27-29mpg. Performance is now 280bhp from 232bhp....and what a difference !
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
