X5 E70 Body Face lift ? UPGRADES ?
Hi all ,
Ive just bought a 2007 E70 3.0D SE and looking to give it a face lift.
I was wondering if its possible to buy more sporty or newer body kit to fit to my car ?
Ive looked at Msport kits or newer parts , but not sure if they will fit like for like or require some work ?
Thanks all
Thanks all
- weaselchops
Re: X5 E70 Body Face lift ? UPGRADES ?
Been thinking the same......
Maybe at the very least colour coded trim!
Also check out, the "Aero kits" kits on ebay.
Isn't going to work out cheap though![Sad :(](./images/smilies/sad.gif)
E70 2008 3.0sd, 7 Seats.
i havent looked on ebay yet , but how much are the kits ?
Hi all ,
I'm looking at potential upgrades to my X5 se .
I've been looking at upgrading the lights to LCI ? To adding an Msport or Aero body kit?
I'm just not sure what the differences are and if it's worth doing ??
Sent from my SM-G935F using Tapatalk
All down to personal preference , easiest fix is new wheels and tyres this always gives a car a refresh along with grill change , M Sport extended arch kit moves you up to 20" wheels and tyres as they stick out of the arches if fitted to an SE X5 which is an mot fail .
Some Se versions have been factory fitted with the arch extensions although they are usually not body coloured like the M Sport , you can buy kits from BMW although lots of kits on eBay which are cheaper but a lot more work to fit , other options could be a local breaker .
Good luck
Sid10
Good luck
Sid10
Apologies if It seems like a silly question , but is there a side by side comparison of an SE and msport together as many bodykits on eBay just shoe extensions ? And not full bumpers ?
Also mine does have non coloured arch trims but I didn't realise that they were the arch extensions ?
Regards
Regards
This is very similar to mine , with the black parts on the front and arches ?![Image](https://uploads.tapatalk-cdn.com/20180304/34ea57d8e07cf941ac5d74d4dee38451.jpg)
![Image](https://uploads.tapatalk-cdn.com/20180304/8a61f6b6b399490c6b539d02d942b876.jpg)
Hi the main difference is no side steps , front and rear bumpers are also body coloured .
So does that mean if I colour the front and rear bumper and the arch extensions , it's an msport from the outside? Also given all that am I correct in thinking that you can buy bumper extensions??
EBAY....TAKE A LOOOK AT.......332474585563
With painting I guess approx £450, but a bargain for the face lift I guess??
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
