Help needed please
X5M50d
Help needed please
Post by X5M50d » Sun Feb 04, 2018 7:58 pm
M50d had its fortnightly valet today and tops ups.
I wanted to top up the tyres however I can't remove the valve caps that I replaced last year for the black plastic ones (they are metal caps). They seem to be welded on :(
Anyone else had this problem and any ideas how to loosen up?
Re: Help needed please
Post by X5Sport » Sun Feb 04, 2018 8:02 pm
A drop of WD40 or light machine oil will do it, and leave for an hour or so.  Metal caps look great but the metal to metal contact causes them to grow into each other because of the brass alloy usually used.
pvr
Post by pvr » Sun Feb 04, 2018 8:13 pm
Turn the wheels so the valves are on the top of the wheel, the release oil will drip into the caps instead of on the wheels that way.
When I had metal caps, I turned them every week to ensure they would not weld on.
Post by X5Sport » Sun Feb 04, 2018 8:20 pm
Or use and earbud to apply just a smidge  :)
Dogzyboy
Post by Dogzyboy » Sun Feb 04, 2018 8:24 pm
Not much help just now, but Copper grease should stop them from ceasing in the future.
X5M50d
Post by X5M50d » Sun Feb 04, 2018 8:33 pm
Cheers Guys!
mogsyman
Post by mogsyman » Mon Feb 05, 2018 8:33 pm
Sadly all too common that aluminium literally welds itself into steel.
We use both metals together frequently and have to be very careful.
It’s quite possible you may not move them but a good soak as mentioned may well help, good luck!
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
X5M50d
Post by X5M50d » Tue Feb 06, 2018 10:05 am
Not budging!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! >:(
Hope this does not mean new TPS's?
mogsyman
Post by mogsyman » Tue Feb 06, 2018 1:39 pm
[quote="X5M50d"]
Quite possibly.
If they've welded themselves together you're in the brown smelly stuff  :(
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Nictrix
Post by Nictrix » Tue Feb 06, 2018 3:34 pm
Do none of you check the tyre pressures every now and again?
Although there is TPMS on the car it doesn't really recognise slight pressure drops.
I check and adjust the pressures every other week so the caps don't get a chance to seize on.
RichM50d
Post by RichM50d » Tue Feb 06, 2018 5:03 pm
[quote="Nictrix"]
Really?????!!!!!!!!!!!! :blink:
Post by X5Sport » Tue Feb 06, 2018 6:25 pm
[quote="RichM50d"]
[quote="Nictrix"]
I did the same when I had metal caps, and also put a smidge of silicon grease on the threads.
You could try very gently warming them too - not enough to burn you though.
Nictrix
Post by Nictrix » Tue Feb 06, 2018 9:53 pm
[quote="RichM50d"]
[quote="Nictrix"]
Yep. At the end of the day the set of tyres is close to a grand and I would like them to last as long as possible.
I also think that cars (and bikes) feel better and handle better with the correct pressures in the tyres all the time.
Dogzyboy
Post by Dogzyboy » Wed Feb 07, 2018 10:39 pm
I’m worried about mine now. I might have to check the copper grease is working. Either that or check my tyres every second week!  :D
IanP
Post by IanP » Thu Feb 08, 2018 7:50 am
I check my bike tyre pressures before every ride out (or every session on track..), but rarely bother with the car. Sheer laziness I guess.
But I wouldnt reccommend copper based greases in this instance, vaseline or silicon grease maybe.
Or a plastic valve cap  :)) :)) :)) :))
