Loose sensor
Murphybarnes
Loose sensor
Post by Murphybarnes » Sun Feb 04, 2018 5:03 pm
Found this flapping about when washing the rear right wheel. Connects to the black sensor thingy but I cannot find where the loose end connects to or if there is something missing.ImageImageImageImage
Sent from my SM-G935F using Tapatalk
2006 3.0d Le Mans.
Re: Loose sensor
Post by Alan Gunn » Sun Feb 04, 2018 5:18 pm
Fit's on the brake pad it is the sensor that tell's you when they need changing.
Murphybarnes
Re: Loose sensor
Post by Murphybarnes » Sun Feb 04, 2018 5:31 pm
Thanks. Do I have to take the caliper/pads apart to reconnect it?
2006 3.0d Le Mans.
Re: Loose sensor
Post by henrym3 » Sun Feb 04, 2018 6:49 pm
No look at the metal edge of the pad (backplate)and there will be a recess/groove for that piece to push into. probably wasn't pushed in properly in the first place.
VW R32 Gone
Murphybarnes
Re: Loose sensor
Post by Murphybarnes » Sun Feb 04, 2018 7:23 pm
Ok thanks for that. Was fading light and hauling these 315's off continually is not doing my back any favours.
2006 3.0d Le Mans.
DJ_x5
Re: Loose sensor
Post by DJ_x5 » Fri Feb 09, 2018 2:43 pm
If you haven't already done it you should be able to get the pad sensor back in the pad using a little grease without removing the wheel
