Km to miles
Posted: Fri Feb 02, 2018 3:04 pm
by shodan70
Hi just been messing around in car and for some reason my display is now in km anyone know how to change this back to miles please
Re: Km to miles
Posted: Fri Feb 02, 2018 3:27 pm
by mogsyman
[quote="shodan70"]
Go to Units, then distance and finally scroll between km & m and hit enter.
Here you go
simples :punk:
Re: Km to miles
Posted: Fri Feb 02, 2018 3:41 pm
by shodan70
Hi it’s a53 plate without I drive
Re: Km to miles
Posted: Fri Feb 02, 2018 3:49 pm
by mogsyman
[quote="shodan70"]
ah............ :sorry:
No idea.................
Does that help at all?
Re: Km to miles
Posted: Fri Feb 02, 2018 3:51 pm
I think it’s in ‘Settings’ or under the ‘Menu’ or similar option on the head unit (if you have Nav). I sold mine a while back and am trying to remember what the pre iDrive system worked like.
Re: Km to miles
Posted: Fri Feb 02, 2018 3:52 pm
by shodan70
Have nav but it won’t change in the options Just stays on km
Re: Km to miles
Posted: Fri Feb 02, 2018 3:55 pm
Have you changed anything else, like the language or fuel units? That might force metric instead of imperial?
Re: Km to miles
Posted: Fri Feb 02, 2018 3:58 pm
by shodan70
I did change language to German accidentally when I realised this I changed it back to uk
Re: Km to miles
Posted: Fri Feb 02, 2018 4:51 pm
by henrym3
Think you also have to ensure/set MPG as well
Re: Km to miles
Posted: Fri Feb 02, 2018 5:41 pm
by shodan70
Nothing will reset
Re: Km to miles
Posted: Fri Feb 02, 2018 6:17 pm
by henrym3
Then one must assume there is some other problem, check all the connections to the HU and in the boot area,
Re: Km to miles
Posted: Sat Feb 03, 2018 3:59 pm
by Dannyh172
[quote="shodan70"]
Had this same problem yesterday!
Hold down left button by the speedo,
Turn key 1 click forward,
Turn key back to off position,
Let go of button.
Turn ignition on and should have changed outside temp and climate as mine did!
HTH
Dan
Re: Km to miles
Posted: Sat Feb 03, 2018 10:46 pm
by shodan70
Yeah dan it changed temp but it’s km to mph trying to change thanks
Re: Km to miles
Posted: Thu Feb 22, 2018 7:13 pm
by shodan70
managed to sort this using bmw scanner 1.4 thanks all now just got to get my obc to work as it went off sorting rest out
Re: Km to miles
Posted: Thu Mar 15, 2018 1:54 pm
by pvr
You were probably thinking of the navigation side - I always had mine on Km for navigation purposes as "turn right in 900 yards" meant nothing to me, whilst the metric version is fine for me
