USB Help
ttr
USB Help
Post by ttr » Mon Jan 08, 2018 7:59 am
Morning all,
As you may know i'm better with spanners than electrics - so i know when to ask for help!
I want to try and either:-
Run a USB port so i can plug in my iphone and listen to music or
Run a USB port that allows you to charge
both is preferable but i 'm not too confident with electrics so will opt for the easier option if this exists !!
From the forum i gather you can buy a USB port and wire it in via the back of the radio and then mount in the ashtry area, this appears realtivley simple from the kit - has anyone done this and can confirm the bm part number i need or other supplier ?
Anyone fitted a charging USB port and if so what parts did they use and is there a How To anywhere.
Thanks i advance for any input into this.
snrbrtsn
Re: USB Help
Post by snrbrtsn » Mon Jan 08, 2018 11:59 am
Available from many sources
I note the bmw sockets sits flush whereas other units sit proud
In regards to music streaming, I’m probably not the best person to ask
Available from various auction / Market sites or filling stations
ttr
Re: USB Help
Post by ttr » Mon Jan 08, 2018 12:36 pm
snrbrtsn
cheers for the response.
i take it these just push into the lighter socket  - which will work to be honest, i just was hoping for more of an oem fit / look so they sat flush (if you get my drift) . Good news even i can fit this electrickery !!!!!!!!
will look at the site now to see what it looks like.
cheers again
Re: USB Help
Post by X5Sport » Mon Jan 08, 2018 5:55 pm
Not sure that a USB option was ever supported on the E53.  The iPod kit wired into the Radio head up front but only had a 3.5mm audio socket on it.  It then plugged (via a separate lead) into the headphone socket - which Apple have also discontinued.
snrbrtsn
Re: USB Help
Post by snrbrtsn » Mon Jan 08, 2018 6:28 pm
Oh, did I mention they illuminate green........
alan996
Re: USB Help
Post by alan996 » Mon Jan 08, 2018 7:45 pm
[quote="snrbrtsn"]
[/quote]Just check the output rating...
I got 2 of them (one for each of our cars) only to discover they are 1amp output - which would barely keep power in a phone.
I did find a generic one in a petrol station that is pretty flush and rated for 2.1a output
Sent from my Pixel using Tapatalk
ttr
Re: USB Help
Post by ttr » Mon Jan 08, 2018 7:50 pm
Wow green I’m sold
Will check output as its something I would not have registered,,,,
Cheers snrbrtsn
Thanks X5sport I read as much but wanted to check my understanding ( which is limited in this area)
ttr
Re: USB Help
Post by ttr » Thu Jan 11, 2018 1:12 pm
All,
To close this thread i ordered a Ravport Mini dual port aluminium flush fit usb great piece of kit build quality good for the money.
Took your advice on charging rate  - thanks for that would never have considered it.
