We are starting to see water damaged engine ecus on the e70 x5
We have replacement refurbished Dme and dde in stock which are the same as you would by from a main dealer
These will need to be programmed to the car as a new by a bmw specialist with the bmw diagnostics system or a main dealer
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW,Alpina Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal of its guts or replacement
40% of my work is repairing the problems that are caused by other tuners Remaps
0208 561 1818
07831 103030
Hayes
UB3 1BB
Water damaged or faulty E70 engine ecu (dde Dme)
- jason@bwchiptune
- Contact:
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
Re: Water damaged or faulty E70 engine ecu (dde Dme)
Where are these units mounted, and why are they getting wet?
Nine468
Yes it would be good to know where they are, and why there getting wet, so we can put preventative measures in place...
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
