Does anyone know what a Carly fault code of 009C55 is?
Carly is saying PTC Auxillary heaters. I don’t have the aux diesel heater so I can only assume this relates to the electric module in the heater matrix as is fitted to diesels.
But a google search is showing the fog sensor?
The wind screen does fog up and a new sensor I think is needed? But the fault code for this usually shows up in the roof section diagnostic on Carly, but know seems to have disappeared.
Anybody else had this?
Fault code 009C55
Stuboy
- weaselchops
Re: Fault code 009C55
http://www.bimmerfest.com/forums/showth ... p?t=828653 this looks helpful?
Do you find it slow to warm up?
E70 2008 3.0sd, 7 Seats.
Stuboy
Not at all.
Stuboy
All sorted turned out to be the fog sensor which didn’t throw an error code.
Personal note, it has to be an e70 sensor as others do work but no correctley!
