This is a professional system for remapping cars and is used by many tuning companys around the world
it is nice and easy to use and will save the trip to us for those of you that are to far away or from a different part of the world
1,Instal the xconsole sofware on your pc,
2,Connect via usb,
3,Pick the car you want to read(or we can set this when we send it),
4,Connect the xconsole OBD flasher to the cars obd socket,
5,Then follow the on screen instructions,to id and read ecu
6,Then reconnect to the pc,it will then save your file on your pc,
7,Email this to me at info@bwchiptune,
8,I will then make the mods to your cars own ecu maps for power or more mpg or both
9,i will email you the mod file back to you
10,Up load this mod file to the xconsole OBD flasher and then connect to the car,follow instructions to flash remap mod to the car
You can then use the xconsole OBD flasher to flash back to orignal file any time
The xconsole OBD flasher can upload your mod or orignal files as many times as you like,The orignal will aways be held on the xconsole OBD flasher
If you sell your car you can flash the car back to orignal and reset the xconsole OBD flash to the new car,will need to buy a new mod file for new car
The Xconsole OBD flasher will also read and clear fault codes on the engine's ecu for E71 X6 3.0d & 3.0sd(3.5d)
The xconsole OBD flasher is compatible only with Windows XP - Service Pack 3, Windows Vista and Windows 7
FOR E71 X6 3.0d & 3.0sd(3.5d) ONLY
Xconsole OBD flasher and 1 mod file will cost £425 +p+p
Xconsole OBD flasher and 2 mod files(ie power and eco mods)will cost £475 +p+p
XDRIVERS OFFER FOR TILL 30/4/11 WE WILL DISCOUNT THE XCONSOLE OBD FLASHER BY £50 PER UNIT
FOR E71 X6 3.0D & 3.0SD(3.5D) ONLY
Xconsole OBD flasher and 1 mod file will cost £375 +p+p
Xconsole OBD flasher and 2 mod files(ie power and eco mods)will cost £425 +p+p
List of other vehicles xconsole OBD flasher can be used on HERE
E71 X6 REMAP OFFER FOR £275, SYSTEM TO FLASH YOUR CAR AND RETURN FLASHER TO US AFTER REMAP FLASHED
The remap your car will cost £275 +p+p for the postage and we will need a deposit of £250 for the OBD flasher pro,
The deposit of £275 will be refunded on the return of the OBD flasher pro,so you will still get your remap at the BWchiptune forum price of £275 for E71 X6 3.0D& 3.0SD(3.5D)
for more info call jason on 0208 570 3600 or 07831 10 30 30
