Just wondering which power Steering fluid I can buy for my 3.0d.
I can't seem to able to identify one in Halfords or ECP
Final question is where the fit mark is? there is no mention of it in the hand book
cheers
Which power steering fluid
cooa99
Current Cars BMW 2005 X5 3.0d ; Golf 2003 1.9 TDI for the High Miles Journey to work
- henrym3
Re: Which power steering fluid
Normal ATF. BMW list it as Dexron 2. When you remove the filler cap it has like a rod in the middle there will be 2 scribe marks on it. Level should be in between always try and get it at the high mark, then when you check it if it needs topped up you got a leak. system shouldn't use any fluid
VW R32 Gone
VW R32 Gone
cooa99
Thanks very much.
will this for ECP be ok?
https://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/car-tranmission-oils/automatic-transmission-fluids/?522776082&0&cc5_869
- henrym3
That'll do just fine
VW R32 Gone
VW R32 Gone
cooa99
