Cold snap, Webasto question
marinaman
Contact:
Post by marinaman » Fri Nov 17, 2017 11:05 pm
Hi all
First 2 c  so after checking cleaning etc  fitted new fuel gauze in the Webasto, it actually fired up and the heater body got quiet warm to the touch though the exhaust was coolish,  after few mins though it shuts down,    if i stop car and restart,  the cycle repeats,  fires up, fan humming , fuel pump ticking about once a second,  then for some odd reason the pump stops  and it dies down.
Any ideas welcomed,  have read all the posts,  but havent found my problem covered, its usually none start,  but mine does run a short time.
Re: Cold snap, Webasto question
Post by X5Sport » Sat Nov 18, 2017 8:49 am
Engine running all the time?
Does it stay running if you put 12v on Pin 1 of the connector?
If it’s ticking and getting warm that sounds hopeful but it may not be sustaining a flame?
Could be battery voltage a bit low if engine off, or coolant temp is above minimum, or internal temperature sensor not seeing the system as having fired up properly and staying ‘lit’.  The exhaust does remain cool, or it did on mine.
Just thoughts.....
marinaman
Contact:
Post by marinaman » Sat Nov 18, 2017 5:15 pm
This was with engine running and after a full conditioning charge as went low after not running for a month,
will try it with 12v on pin 1 tommo
very frustrating,  you think you fixed it and dies again
Paulw
Post by Paulw » Sat Nov 18, 2017 7:14 pm
just a thought new to this site could it be the water circulation pump not working and the unit is getting too hot and shutting down????
marinaman
Contact:
Post by marinaman » Sat Nov 18, 2017 10:18 pm
thanks.  but  no . pump running as one of water pipes on heater getting warm, dont think it running long enough to overheat
