I recently drove my new X5 at night for the first time and found the satnav very bright. After a bit of fiddling i found the settings with night mode
I selected night mode and it was much better in the dark but it is now in the darker "night" setting all the time day or night.
Is there a setting hidden somewhere to have the day/night mode automatic when the lights are on (like my landrover did) or is it a case of manually selecting day or night mode
Paul
Satnav day/night mode??
- snrbrtsn
Re: Satnav day/night mode??
You can dial in the shortcut menus (1-8) to select day or night
I have number 8 as a shortcut key to switch between day and night mode, number 7 does surround sound
Realistically the only two buttons I frequently use
Otherwise it’s a fiddle through idrive menu, though I’m sure it switches between modes if lights are set to Auto (I could be wrong, last car did)
Auto day/night switching not on E53 or E70/71 despite VW having it since the 1990’s. I wondered if there was a Patent on it somewhere.
I hadn’t thought about coding it into one of the ‘quick keys’
Sit
Mines coded to ‘magic’ button 8, press once for night mode, press again for day mode - :winkg:
Si
Si
2010 X5 30d M Sport Carbon Black | Camel Leather, 20's | HUD | Shadowline | Privacy | CIC iDrive | Adaptive Drive | Pro Nav | Loudspeaker Audio | High Beam Assist | Enhanced Bluetooth | Media Pack | Bum Warmers!
- snrbrtsn
Think it’ll be easier to follow the video as opposed to me blathering
Works irrespective of model
https://m.youtube.com/watch?v=PScSSoVNmlA
