E83 X3 Tyres query
Posted: Thu Nov 09, 2017 11:44 am
by NickM
Hi & sorry if this is dredging up old stuff, but I'm looking for some advice.
I have an E83 X3 2006 2.0D manual MSport. I've had it for about 10 months with no problems.
When I got the car there were a pair of brand new Pirelli PZero's on the back (255/45 R18) & a pair of Fulda's (?) on the front 235/50 R18 which were about half worn. As you can see it is a staggered set up.
No problems at all, no knocking or anything. However I've just had a couple of occasions when the trio of lights comes on if cornering quite fast & it feels awkward if pulling away from a standing start with some lock on the steering. I reckon it is time to replace the front tyres as they are now virtually at the markers.
The rear tyres are absolutely fine with loads of tread left.
On the basis that it was running absolutely fine with different brands on the front & rear axels, logic says replace like with like, however I can't seem to find Fulda tyres anywhere, so do you think it would be OK to put 2 brand new Uniroyal Rainsport 3's or 2 brand new Avon ZX7's on the front?
Or do you think it would be best to put 2 new Pirelli's on the front to match the rears?
Thoughts/advice would be appreciated.
Re: E83 X3 Tyres query
Posted: Thu Nov 09, 2017 5:10 pm
Firstly :hi:
Secondly X3’s are very intolerant of having other than the correct tyres.  Too many members on here have found that not fitting ‘*’ rated tyres on staggered setups frequently means a destroyed transmission!
BMW matched rolling radius tyre sets have a ‘*’ on the sidewall.  Given you are getting warning lights I suspect the car is telling you to put a full set of the right type on.
Wide variation in tread depth will also break the transmission.  It is not such a problem on non-staggered wheel sets and those can have pretty much any set fitted as long as the tread depth is kept within 1.5%.
Posted: Thu Nov 09, 2017 9:06 pm
by kkx5
4xUniroyal Rainsport 3's. Do not mix tyres on x3.
