Gearbox oil
- BigRick
Gearbox oil
I’m doing an oil change on my ‘53 auto gearbox. My question is about the oil. It’s the 5speed GM box. Now I get 50% discount on GM oils. So what oil am I looking for? Is there a certain spec or is it just auto gearbox oil? Thanks
Re: Gearbox oil
This might help.
Slide from Realoem. Lists ATF1 as well.....
http://www.realoem.com/bmw/enUS/showpar ... Id=24_1371
There is often a label on the gearbox as well. Remember to follow the correct change procedure. It isn’t a drain and refill job. You need the car level, in the air, engine running once partly filled, at the correct temperature and cycle the gears, then recheck the level and top up.
Never anthropomorphise computers. They hate that.- BigRick
Re: Gearbox oil
