Wheel bearing
Silverfox58
Wheel bearing
Post by Silverfox58 » Mon Oct 30, 2017 2:49 pm
Just a quick  question dose  it matter  what way round they go in,
X5 30d
Re: Wheel bearing
Post by Alan Gunn » Mon Oct 30, 2017 4:57 pm
Don't think so.
Changed one or two in my time and if it was that one i would just fit it.
Silverfox58
Re: Wheel bearing
Post by Silverfox58 » Mon Oct 30, 2017 6:30 pm
I only ask as they have as they have an integrated abs sensor ring in them
X5 30d
X5-D-Sport
Re: Wheel bearing
Post by X5-D-Sport » Tue Oct 31, 2017 1:46 pm
either way is good.
Silverfox58
Re: Wheel bearing
Post by Silverfox58 » Tue Oct 31, 2017 3:31 pm
thanks for your reply and advise
X5 30d
moose04
Re: Wheel bearing
Post by moose04 » Tue Oct 31, 2017 5:07 pm
front wheel?, bearing must go in the right way around as its fitted with an exciter ring to activate the abs, be aware of cheap bearings of fleabay etc
Re: Wheel bearing
Post by henrym3 » Tue Oct 31, 2017 5:38 pm
If that's the case how does one know, surely if there was a right way round there would be an arrow/instructions
VW R32 Gone
Smeeagain
Re: Wheel bearing
Post by Smeeagain » Tue Oct 31, 2017 5:47 pm
I hate it when one person responds on a forum saying it do this way and someone else responds saying do it that way. The forum should be a place of advice where the integrity of the advice is beyond reproach. One of the posters is wrong.
There is a right way to fit them or there isn't. As Henry says if they were directional, which would tell you which way to fit them, it would (probably) be marked
Ask the supplier you bought them from.
Silverfox58
Re: Wheel bearing
Post by Silverfox58 » Tue Oct 31, 2017 5:52 pm
Well I have fitted  it with the little  taper first and the wrighting facing at the top as you look at it
X5 30d
moose04
Re: Wheel bearing
Post by moose04 » Tue Oct 31, 2017 7:03 pm
i had two bearings, one off ebay and another from euro car parts, both had no exciter ring built in apparently (they must have been made in china), i ended up taking it to main dealer as i could'nt fathom out what was happening { abs light and a dsc light on).
so i purchased a bearing from my local bmw dealer when i collected the bearing the workshop foreman marked which side went in first, could'nt see any difference in either side, hey presto like new
