TAKING THE DPF OFF
phillip
TAKING THE DPF OFF
hi to all,just joined and looking for some advice,i have a 2009 x5 E 70 3 d x drive,had the message come up dpf blocked,i have just finished removing the dpf and o my god what a nightmare,just wondering if anyone else has removed one and can give me any advise about making to refit any easer,thanks in advance
Re: TAKING THE DPF OFF
Sorry never removed one myself, but can imagine it being a nightmare. The reason for my reply is that some members have had DPF's not regenerating due to the glowplugs and Glowplug controllers, which are a common fault on the E53 E83 E 70 as well as all diesel powered BMW's
Get the fault codes read to see if this is the case.
I had to change my glowplugs and glowplug relay on my E83, as have several others.
The DPF will not regen if the glowplugs / glowplug relay are shot.
And I'm sure you won't want to have to take the DPF off again if you can help it.
phillip
Thanks for your reply, and yes I have glow plug and relay faults, also had 480aand 480 ( think they were the codes) I may as well do the plugs and relay at the same time I guess, once again many thanks
Nine468
Have you or are you sending the dpf off for a professional clean.?
Yes its definately VERY wise to do the glow plugs and controller whilst your at it, as thats probably whats caused the dpf to become blocked.
Also do you know when the last time your engine and egr thermostats were replaced, as they can be troublesome, if they dont read the correct temp, the car wont even try to regen..
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
- LincsX5
I have codes for 3 glow plugs but it still regens? I have previously changed both thermostats after noticing a drop in mpg which I would of noticed earlier if it had a temp gauge but had to use the hidden menu to find the coolant temp. I’ve since got Carly, which is much easier.
2008 E70 3.0D SE Dynamic kit
2006 SAAB 9-3 Aero
2002 E46 318Ti SOLD
1972 Triumph Spitfire
2006 SAAB 9-3 Aero
2002 E46 318Ti SOLD
