OEM Style / Hidden Dashcam for e53
extremezmachine
Post by extremezmachine » Sun Sep 24, 2017 3:07 pm
I saw this dashcam for sale and looks very oem like.. which is what I am looking for... however I am not sure if the quality is acceptable as I have ZERO experience in this area... anybody can give some inputs?
https://www.aliexpress.com/item/Factory ... 8de8f91d41
Re: OEM Style / Hidden Dashcam for e53
Post by X5Sport » Sun Sep 24, 2017 4:31 pm
1080P is the minimum you should use these days - and is the same quality as HD Blu-ray Discs.
As to how good it is in reality I cannot say.  It has to be connected to 12V power and to the OBDII (diagnostics) socket as well.
I use a Nextbase 512G if that is of any use.
You need to look for low light performance as well as normal light.  Some cameras perform perfectly well in daylight but are rubbish at night.  Worth seeing what on line reviews are around to get real world info before you commit  :)
Post by henrym3 » Sun Sep 24, 2017 6:34 pm
Depends what your looking for, I don't like having a camera with a screen on the dash, to big and I can see where I'm going. I have a tiny camera which loop records with ignition on and it is connected to my head unit but I never look at it, had the SD card out and viewed on my computer it's 1080 and a perfectly adequate picture to view faces number plates etc.  If your looking something to record your holiday journey on perfectly clear long range video then it's not for you. I'm pleased enough to be getting another for the rear window and only look at the SD card if there's an incident. Item 322599332630
VW R32 Gone
Colin
Post by Colin » Mon Sep 25, 2017 11:08 pm
I use the Nextbase 512 gw , same as X5Sport    brilliant dashcam  and has 140 deg camera etc etc
05 , 30d Le Mans Blue Sport
