Noise when ignition off
Posted: Thu Sep 07, 2017 3:59 pm
by Zedhed
Another little niggle now.sounds like a small fan is slowly running when ignition is off.sounds like its coming from climate control panel.is this normal.
Re: Noise when ignition off
Posted: Thu Sep 07, 2017 5:20 pm
by sleepyfolk
If it is the tiny fan in the climate panel I'm not sure what causes that to run when the ignition is off, if it's actually the main blower that is still blowing on low speed when your ignition is off it's likely to be the final stage resistor (or hedgehog) as its affectionately known, when it goes rogue the main fan does what it likes even with the key out and kills your battery!
Changed mine recently, £70ish from BMW I think, cheaper eBay versions are available but I read about a few cheapies going duff very quickly so went original.
It's behind the panel by your left ankle
How to ere http://www.pelicanparts.com/techarticle ... cement.htm
Posted: Thu Sep 07, 2017 10:05 pm
by Zedhed
Ok thanks mate.just tried pulling fuses relevent to the climate but to no avail,its still running.going away for the weekend tomoz and really could do without it killing the battery even thougj its brand new.
Posted: Fri Sep 08, 2017 12:58 am
by sleepyfolk
I was actually pleased mine went when it did as I had just bought a new Bosch battery which I was about to fit, I guess if you're going away all you can do is take the trim piece off and unplug it
