Page 1 of 2
				Replacement 10.25" screen, with built-in Android!
				Posted: Mon Aug 28, 2017 8:30 pm
				by weaselchops
				Hi guys,
Got round to fitting my 10.25" Android into the bus yesterday.
Got it from here:
https://avinusa.com/10-25-bmw-x5-x6-ser ... ystem.html
Was reasonably straightforward. Plenty of YouTube help available.
My E70 had no USB or Bluetooth audio, so this kills 2 birds
The screen looks amazing!
It can operate in "pass through"  So you can use your built-in CCC or CIC system whenever you want.
Hmm tinypic won't let me upload this pic!
http://imgur.com/a/tsXZb
All good, apart from the supplied GPS antenna is blocked by  my Comfort windscreen
 I will look into using the BMW antenna soon.
				Re: Replacement 10.25" screen, with built-in Android!
				Posted: Tue Aug 29, 2017 6:04 am
				by Alan Gunn
				Posted: Tue Aug 29, 2017 6:35 am
				by kjb1
				wow!! looks great
				Posted: Tue Aug 29, 2017 7:52 am
				by pcdee
				Bloody hell....looks amazing!!
				Posted: Tue Aug 29, 2017 11:58 am
				by mac1986
				wow that really looks the part!
				Posted: Tue Aug 29, 2017 1:44 pm
				I had the same issue with GPS on my E53 and fitted a small antenna up beside the mirror - do the system allow for an external connection?
The E53 had a 'window' either side of the mirror and bottom centre of the windscreen where the filter was absent so that little GPS aerial could be fitted.
I used something similar to this with the same SMA aerial connector....
https://www.amazon.co.uk/External-Anten ... ps+antenna
				Posted: Tue Aug 29, 2017 2:12 pm
				by weaselchops
It comes with one of those antennas. Never thought to test it right up there!
Routing the cable up there would be fun I imagine!
				Posted: Tue Aug 29, 2017 2:19 pm
				Check if the screen has the small cutout area first!
I have been able to run wires to the dashcam behind the A-pillar trim just by pushing it into place with a trim tool - spoon handle does the job too - and behind the headlining without removing anything.
I have gone around the edge of the dash on the passenger side and then found routes in behind the glovebox or above the footwell top carpet trimming.
				Posted: Wed Aug 30, 2017 12:31 am
				by celica
				[quote="pcdee"]
That was what I was thinking
				Posted: Wed Aug 30, 2017 12:44 pm
				by scz4
				How's the sound quality?
				Posted: Wed Aug 30, 2017 1:08 pm
				by weaselchops
				[quote="scz4"]
MP3 and Spotify good.
Bluetooth a bit muffled. Haven't really played with the settings much yet.
				Posted: Mon Sep 18, 2017 4:01 pm
				by jeepstertim
				Could I ask what you ended up paying, were you clobbered for import duties?
				Posted: Mon Sep 18, 2017 4:04 pm
				by weaselchops
				[quote="jeepstertim"]
Just shy of 600gbp. Didn't get clobbered!
				Posted: Tue Sep 19, 2017 12:04 pm
				by jeepstertim
				Thanks for the reply, I am about to do the same through Avin.  Could you confirm that the FM and the DAB work in the UK?  Are there any negatives so far?
				Posted: Tue Sep 19, 2017 12:14 pm
				by weaselchops
FM just passes through from your original unit. Do mean DAB as an optional extra from AVIN? If so check to see how it works. As they selling DVB-T sticks and using some poor excuse of an App on store! The DAB extra wasn't available when I got mine... Be interested to know.
Negatives:
Slow to start. But not unbearable.
The default launcher is very rigid and won't let you change the default music app or add your own Apps to the  carousel.
Sound quality isn't quite as good as the factory sound. But passable.
