'Judder' between 1500-2200 revs - any ideas?
Posted: Mon Aug 28, 2017 10:44 am
by MarkG_M3CP
I have a 50d with 22k miles (1 year old) which has developed a strange judder at 1500-2200 revs.
Seems to happen in any gear and any speed with revs being the only constant. I describe it as a 'judder' as I can't describe any better!
As the engine is pulling it almost feels like the car is hitting some kind of limiter; like a pulsing from the engine/gearbox which clears as the revs build. It's a bit concerning since I understand this to be the second turbo range but booked in to service in a couple of weeks to check out.
Anyone experienced similar?
Re: 'Judder' between 1500-2200 revs - any ideas?
Posted: Thu Sep 28, 2017 4:00 pm
by Nine468
Did this get sorted out at the dealers..??
I had something similar, a seeming missfire/hesitation [40d] , it turned out to be the transfer box failing, Was fixed under warranty...
Posted: Thu Sep 28, 2017 4:03 pm
by MarkG_M3CP
[quote="Nine468"]
I traded the car in for an M3  :))
...but you are correct, the senior tech diagnosed the fault to be the transfer box.
They didn't replace it in the end - just balanced the wheels and said it was fine  ::)  It wasn't, but their problem now  :P
