Hi All
OK replaced the seat control switch module, now Airbag light is on
Can members please share What / Which Software or Device Unit to use/purchase to clear the error ?
I see on "that" auction site there is a "B800 Airbag Reset Tool Diagnostic Scanner Code Reader" not expensive, but does it do the job?
thanks all
regards
Rich
Resetting Airbag light on dashboard - Which Software or Device to use?
- shy7g
Re: Resetting Airbag light on dashboard - Which Software or Device to use?
Better off getting a c110 or a c310 scanner to turn off warnings.
Well that's what i and many other members use.
- lezmtaylor
I bought a Creator C310 from Amazon, Cost £44.99 works great and has brilliant feedback.
Lez
Lez
- shy7g
Thanks for all the feedback
Will I need to purchase the BMW 20 Pin to OBD2 16 Pin Scanner Connector Adapter Cable also to use the
C310 scanner or can it be plugged into the 16 pin socket inside the vehicle?
thanks
Rich
thanks
Rich
Plug it in inside the car.
XK8
I used a C110 on my 2007 X3, plugged into the obd port by the front footwell.
Current Garage
2007 BMW X3 3.0sd M-Sport
2004 Jaguar XK8
2010 BMW 330i coupe
1978 Yamaha XT500
2004 Jaguar XK8
2010 BMW 330i coupe
1978 Yamaha XT500
- shy7g
OK ALL
Still pondering which model to purchase??
Which out of the two models, Creator C110 or C310 scanner's is the better model / best value for money?
Can you achieve more with the one model than the other??
thanks
thanks
- lezmtaylor
Have a look on Amazon and compare the two.
My preference was the 310, that is why I bought it.
Lez
Lez
