Hdc & dsc not working.
Zedhed
Got no response from these 2 buttons folks.anyone know what fuse i should check.
Re: Hdc & dsc not working.
12, 51, 55, 63 all in the front board. Covers ABS, ASC, DSC. I think HDC uses the ABS system to drive the brakes.
What warning lights are on, if any?
HDC only works at very low speed and if memory serves only comes on if selected when stationary. The DSC button needs a long press (several seconds).
Zedhed
Ok cheers bud.i have the 4x4 light on.dealer we had it from put the scanner on it for us and said it was steering angle sensor,but i really dont trust car dealers.as for hdc,there is no icon that comes on with the ignition in the cluster.
Steering angle sensor warning could be the tracking has been adjusted and is now out of calibration, or the sensor on the front axle has failed. Both are common.
Someone on here had just this only a couple of weeks back. A search should pull it up.
Zedhed
OK no probs.well I'm planning on looking at a diagnostic laptop in the morning,so hopefully that should sort it if I decide to buy it.
Zedhed
Where about on the front axle os this sensor then.
