injectors might need cleaning?
Ryoken
Post by Ryoken » Tue Aug 22, 2017 11:28 pm
just a quick one really , ive got a slight misfire at about , 2k, feels like its hesitating ,  (if i rest my foot on the accelerator),  i have noticed though the  little mpg gauge , at the time of the hesitation, that does fluctuate slightly ,  and then it feels like it changes gears .?
any whoo,  the car apart from this starts, fine , runs ok , isn't a slouch either, apart from the 15.8mpg,
so , Q is this , do you think it could be the injectors that needs a clean, cars done 156k  and most of the time its filled up with asda or sainsburies unleaded,  not super just normal fuel
ideas?
oh, ive put in new plugs , new coil tubes, cleaned maf, and throttle body.
2002 e53 4.4  tempremental
strummer
Re: injectors might need cleaning?
Post by strummer » Wed Aug 23, 2017 11:30 am
Have you plugged in to see if any codes stored?
Post by X5Sport » Wed Aug 23, 2017 2:40 pm
You can also buy a proper injector cleaner from BMW if you choose that route.
Petrol version is - 83 192 183 738
Cotswold BMW regularly offer it on eBay much cheaper than direct retail from a dealer  :)
I use the diesel version (83 19 2 296 922) in all my BMWs.
themoog
Post by themoog » Wed Aug 23, 2017 8:27 pm
It's not transmission trouble is it? Mine had what I thought was a miss fire circa 2000rpm and 40-60mph. Hesitation was trans judder occasionally. Turned out the trans fluid was shot and never been replaced at 140k.
Ryoken
Post by Ryoken » Wed Aug 23, 2017 10:20 pm
ive tried injector cleaner ,  didn't really do anything , however not tried BMW one
there are no codes stored , actually surprised at that.
i had ALL fluids changed about 9 months, front transfer box rear diff and gearbox,.
im hoping its not trans trouble, it seems like its at low speed ,. maybe 20 to 30 mph, i dont really get it at high speed ,
there is talk in the US about the torque converter being shot, or the  rubber doughnut on the prop?.
tbh, i can live with it , until  it gets that bad where something does go bang :)
Post by Alan Gunn » Thu Aug 24, 2017 7:37 am
Sounds like a car i had some time ago.
Started out like a very slight misfire but got worse and a year later it was like driving on the rumble strip but only coasting at around 60mph.
Turned out to be the lockup clutches in the torque converter.
Ryoken
Post by Ryoken » Thu Aug 24, 2017 12:41 pm
just what I need,  the potential of a gearbox removal to get a TC installed,  if it IS the TC , might as well just get a rebuilt gearbox installed
you know whats scary , I'm in way too much ££ wise , just to say sod it ,  its gone
Post by Alan Gunn » Thu Aug 24, 2017 3:33 pm
I put 2 tubes of "DrTranny" in the box and the problem went away for a month or so but it did confirm the problem.
This is the stuff i put 2 in as you spill a lot.
http://www.ebay.co.uk/itm/2-TWO-Tubes-D ... Sw7NNUEDU0
Ryoken
Post by Ryoken » Thu Aug 24, 2017 10:28 pm
cheers Alan , ill try that.  ill order some tomorrow
Smeeagain
Post by Smeeagain » Wed Aug 30, 2017 11:42 am
[quote="Ryoken"]
ideas?
I get a slight misfire every so often, I put in a can of this maybe twice a year, seems to sort it. https://www.amazon.co.uk/BG244-DIESEL-F ... B0062KYGZC
It's cheaper than she of the other options you are considering so may be worth it. as another poster said, Id get the codes read before I started spending money willy nilly
Smee
Ryoken
Post by Ryoken » Wed Aug 30, 2017 1:08 pm
Hiya Smee :)
believe it or not , there arnt any codes stored !!!!!!
what an e53 with no codes. NEVER :)
I'm taking the shed off the road in a few weeks,  as I'm bringing my (deceased) dads car out of the garage , might as well use that than the X
then I can save some brass, and then I can play with the X without loosing 4 wheels
all I know ive had the car 3 years , its done 156k, and ive allways put sainsburies fuel in , :)
Smeeagain
Post by Smeeagain » Thu Aug 31, 2017 11:43 pm
[quote="Ryoken"]
Hiya Smee :)
No codes stored? Must be a fault lol  :))
Ryoken
Post by Ryoken » Sat Sep 02, 2017 2:58 pm
well ,  that was an interesting afternoon,
decided to put in dr lube :)
parked car on kerb  (drivers side) so I wouldn't get any spillage  and id have room to put stuff in ,
nope wrong ,
ive lost about 1.5 liters of oil  I managed to capture all of it , but still  it tried to escape,
2 tubes successfully in gearbox, ive just got to wait till later and try to get them escapee liters back inside
no I thought  you filled the oil up till it  tricked out then  tightened up da plug,
wheres all this extra oil appeared from
oh , oil was changed maybe 6 months ago , now its a lovely shade of jukky brown ( like a normal oil change on an engine)
oh hum , ill wait till it cools down again ,  will do it tomorrow to try to get oil in
Post by henrym3 » Sat Sep 02, 2017 9:13 pm
Did you have the engine running when you took the filler plug off, like you do for the final top up?
VW R32 Gone
Ryoken
Post by Ryoken » Sun Sep 03, 2017 8:26 am
shit , no , until later I didn't realise you had to do that, good job I didn't drive it ,  ill start the car up later and re put in the rest of it , , hold that thought , ive got some new tranny oil in the shed ill put new in instead of the old stuff
god I'm such a tool :)
