Starting problem.....
Posted: Thu Mar 03, 2011 9:57 pm
Had a similar problem this evening with the 4.8 to one I had about 5 months ago. Car's been running beautifully, no problems there. Went on a longish drive (about 30 miles) at lunchtime to attend a conference, parked, came back to the car about 3-4 hours later and the starter motor just stayed engaged and wouldn't start the car....... After trying about 5-6 times with a few minutes between each try, called BMW Emergency (they must know me by name now!!) Driver duly arrived with a great big low loader, said they weren't allowed to use that can of spray they used to spray into the air filter pipe any more, and after also trying and failing to start the car normally, he first tried locking / unlocking car on the fob (never had problems, but I guess immobilisers can be an issue) and then trying to start - no luck there. Then he shifted the gear lever around a few times, tried starting again, the starter motor kept turning over (it does it automatically on the 4.8, a bit unnerving) and it then eventually roared into life. Floored it a few times and it then sounded absolutely normal and ticked over just as it normally does and never missed a beat. The last time this happened and I had it in the dealers they claimed there were "no stored faults" so they "couldn't investigate or fix it". We are really careful not to use the X for silly short journeys, no sign of condensation anywhere under oil cap, car runs like a dream mostly. The recovery technician said most of time it was down to
a) faulty immobiliser
b)"condensation" problems from multiple short journeys (? didn't think this would prevent starting - just that the oil separator could pop its clogs and cause loads of damage) or
c) a transmission sensor "thinking" the gearbox was not in P and therefore not allowing it to start (but why would it turn over??) and moving the gear lever around through the gears a few times corrected this.
I'm not entirely convinced by the above, but would appreciate any further info / advice as this is the second time its happened in the past 6 months - each time, they've got it going without recovery and the first time there were no fault codes, bet there are none this time either.
Any ideas?? Low mileage (34000 miles), only ever use BP Ultimate (1.44/l
today - cost £119 to fill the tank). Performance usually superb and a pleasure to drive. The V8 sounds great. We're back home now (didn't switch off en route - no tempting fate!!) and safely parked up so will be interesting to see if it starts normally again in the morning etc.
