M sport ride height
Posted: Mon Jul 24, 2017 11:21 am
Is it possible I could request someone measures their ride height
I've a 40d m sport, with self levelling suspension, that I think is running high on front.
The front springs were changed prior to purchase,
I'm taking reference from SE model with the ride heights I found online (picture attached)
My believe is the m sport, should ride 1" lower ???
Is it possible the incorrect springs have been installed, ie Se springs installed to an Msport
I've measured mine from ground to top of arch through the wheel centre cap and have the same measurements as per picture above.
Front 32.25"
Rear 31.75"
I've check spec against Vin & there's no bad road package or m sport suspension delete
Front 32.25"
Rear 31.75"
