Anyone know how to change the Map Colour on the Pro Sat Nav? When you pick a route, the piece of **** uses White to line your route, you can't even make out the route, because the background and other roads are white as well.
So this is rather annoying, I've ended up using the Sat Nav on my phone instead.
Were BMW really that dumb to choose this colour scheme? I've looked in the options/settings and can't find any way of changing it.
Any ideas guys?
F25 Sat Nav Routing, White line for the routing, BMW really?
sharpharp
Nat
Re: F25 Sat Nav Routing, White line for the routing, BMW really?
+1 on this. I find exactly the same issue. Stupid design.
Winslet
Try navigation then settings and there is a map style of standard or alternative. I have changed to the alternative option which makes the background green and the roads are a lot clearer.
Hope that helps.
Hope that helps.
sharpharp
Yoh Winslet,
Thanks for the info, managed to find it in the Info section. The fields are now dark grey, as well as the local roads, but at least the route (still white) is easy to see.
Whoever thought of these "Classic" and "Alternative" skins for their Maps, needs a slap round the chops with a psychedelic paint brush.
