nozzle electrics
Smeeagain
nozzle electrics
Post by Smeeagain » Mon Jun 26, 2017 10:08 pm
The screen wash pumps on my 2004 E53 3.0 are powered, obviously, but in trying to remove the washer nozzles I note that they have a power supply to them also - why???
Smee
lezmtaylor
Re: nozzle electrics
Post by lezmtaylor » Mon Jun 26, 2017 10:19 pm
To heat them up,stop freezing.
Lez
Post by Horizon » Mon Jun 26, 2017 10:19 pm
I believe some have a heater that come on like the heated mirrors ( at a preset temp, supplied. Y the ambient temp sensor. To stop them freezing in winter.
Edit
You beat me to it Lez by 20 seconds
Post by henrym3 » Mon Jun 26, 2017 11:05 pm
I wondered about that, my mirrors defrosted in winter but there's no switch and I just recently undressed the bonnet to have it resprayed and the nozzles have wires attached with no switch. Just proves the point, if you need to know something this is the place to be. :)
VW R32 Gone
Smeeagain
Post by Smeeagain » Tue Jun 27, 2017 9:19 am
Thanks for the promo replies gents, so Henry, if you undressed the bonnet for respraying you can tell me how to remove the nozzles please for cleaning... ? Ive had a look a few times and just see lots of plastic clips to break !!
Post by henrym3 » Tue Jun 27, 2017 7:27 pm
Hi Smee, the electrical connection is a straight forward lift the locking lug a little bit and pull the connection apart. The water line is a pull apart item although it needed considerably more effort, there's no locks or tabs, just a tight fit. This now leaves the washer jet attached to the air vent inlet which I then removed complete, removing the vent is by far the most difficult simply because the tabs are 15 years old and even look brittle, I warmed them with an air gun and found that they needed to be taken out a little at a time, ie push in clip and lift air vent 2mm, work your way round vent till it pops out. Don't know if you actually need to heat the clips or not but as I didn't break any I'd use the method again if needed.
VW R32 Gone
X5-D-Sport
Post by X5-D-Sport » Tue Jun 27, 2017 11:04 pm
So, Henry sir.... what is it that tells the heated mirrors to power-up, do they come on with the heated rear window or simply sense the outside temps when you start up ?
Smeeagain
Post by Smeeagain » Wed Jun 28, 2017 3:59 pm
[quote="henrym3"]
Ok thanks. I want to be able to clean out the nozzles - can you see how to detach them from the vent?
15 years old - wow, you must be on a fair old mileage?
Post by henrym3 » Wed Jun 28, 2017 7:33 pm
Sorry Smee, the air vents are back on now and I don't want to guess at how the nozzles might come off the air vents. The milage is 132k, paintwork is excellent, runs great BUT am just about to replace the rear brake lines.
X5-D-Sport, I don't know for definate but Horizon's take on how they work seems the most likely, I never noticed that they were in sync with the heated rear window. I'll have to wait and hope next winter is horrible so I can do some more investigation ::)
VW R32 Gone
Post by Horizon » Wed Jun 28, 2017 10:34 pm
